Spot Coordinates value not visible
wjkim
wjkim
Spot coordination values are not visible in the project.
Spot elevation is fine.
I copied that object into a new project and applied it, and it works fine there.
Does anyone know which setting is the problem?
joe_keogh
Hi @wjkim
Can you attach the file to your reply so that we can have a look at it?
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
ennujozlagam
need to pick your spot coordinates and edit type and change setting, see sample attached. thanks
wjkim
attach part of the file in question.
_Vijay
open new Revit standard template. copy the coordination famil and paste it will show.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
hmunsell
your Top and Bottom values are set to None.  i beleve that is what @ennujozlagam was trying to show you.
Howard Munsell
wjkim
I didn't recognize that. Thank you.
