Split walls in multiple parts for precast concrete schedule
se.ha
Advisor Advisor
se.ha
Hey community,
I have multiple walls hosting windows, which create openings with the same length as the wall:
It doesn't really make sense to model the two parts (Lintel and Parapet) seperately but in schedules it will of course show the total height of the wall. Is there a way (Dynamo included) to keep one wall but schedule two seperate elements?
Thanks for your ides
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
constantin.stroescu
what about making the facade as a Curtain Wall with system walls and CW windows infillments?
Constantin Stroescu
BDMackey
Often when dealing with PreCast I will use the Revit Parts, generated from the original wall.  if there is a ton of repetition then I simply create PreCast families for what is needed.
