Split face and Split Element
jfjacques
jfjacques
I'm using the split face tool to change the look of the exterior facade.
If I actually want to change the structure or the finish thickness of wall portion - say a small square within a larger wall, I have to use the split element tool.
This this a pain as I can't cut out sections of the wall as I would using the split face tool. Is there a better method?
Sounds like you are talking about embedding another wall type into the wall. This has nothing to do with Split Face.
...Edit Profile and/or Cutting would get you there though.
Embedded Wall:
You can create parts from the wall, divide parts to the section you want to change, turn on shape handle and you can grip edit parts then change to a different material.
jfjacques
If I cut out a piece of exterior finish, say brick, and  change it to a metal finish, I can't also affect the thickness of this material.
In actuality, the metal would be recessed as the brick is thicker. How can I achieve this?
Why don't you just embed a different wall type?
