How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Hi there,
I'm struggling with modelling an external spiral staircase with three landings (ground level, upper floor, roof).
Any idea how to approach it? Multistory doesn't work for with level differences (+0,000; +5,600; 12,000).
Thanks 🙂
You can do 3 different spiral stairs stacked on top of each other. For the intermediate landings, one option is a floor thickness of the metal grate and have it supported by beams like your image shows. Or if it doesn't have to be that detailed you can just use a generic floor.
You might have an easier go it by modeling the first spiral flight (e.g. Level 1 to Level 2) by starting with a Center-End Spiral and then converting it to Sketch-Based and "fine-tuning" the sketch. Afterwards, you can Copy/Paste to Levels.
The logic is simple: a 5'-6" height and a 6'-6" height can only share a common riser height of 6". If your stair riser height is not 6" then one stair will not work. Just create two stairs and add a top landing by sketch for each.
How to buy
Type a product name
