Special-called Wall Partition
ritztran
ritztran
Hi experts,
I'm using Revit 2018.3 full version with GTX 1080Ti GraphicsCard and Windows 10.
I'm trying to create a partition type with 6" metal stud and (2) layers of 5/8" typeX gyp. boards on each side (2-hr rated). It looks normal when we just create a wall type like that and place in the model. However, I would like the gyp. layers stop 2'-0" below the structure for ventilation, and the 6" studs go to under structure. What I can do is that I will have the wall stop under structure 2'-0", and have filled region for the stud. All these will be draw in Detail View.
Any suggestions would be appreciated. Thank you in advance.
loboarch
You can take a look at this video in the Help. I think it will point you in the right direction.
http://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-E11C1335-5CC2-4001-8563-021E01CCF829
Jeff Hanson
Principal Content Experience Designer
Revit Help |
ritztran
Thank you so much.
