Space boundary errors in Revit
seamea12
Message 1 of 10
seamea12
Unexpectedly such a strange space boundry has been created in one of mine typical toilets.Does any know what to do with it?
[ The subject line of this post has been edited for clarity by @handjonathan Original: space-boundries]
Replies (9)
Message 2 of 10
SteveKStafford
It looks there might be a pair of room bounding finish walls in the model along two sides of the shower enclosure.
Steve Stafford
Message 3 of 10
seamea12
Do you have any suggestion how to solve this problem?
Message 4 of 10
seamea12
Message 5 of 10
SteveKStafford
Have them turn off Room Bounding for the finish walls, assuming that's what is happening.
Steve Stafford
Message 6 of 10
blank...
Manually draw space boundaries?
Message 7 of 10
SteveKStafford
Did you use "Automatically Create Spaces"? If so then they need to change the walls in the linked model...I assume it isn't your model? What happens if you delete the space(s) in that room and try to create a new individual space?
Steve Stafford
Message 8 of 10
seamea12
First of all thank you for your advice. Yes I 've created automatically spaces.It's my my model but my friend loaded something new to future dynamo use in terms of flat's sheets for our client.When I delete space in that room and create a new space the effect is the same unfortunately.
Message 9 of 10
seamea12
Hi
You were right with your suggestion. There was space separator but visible in 3d view only(very strange for me!).Thank you.
Message 10 of 10
seamea12
Hi
