Sorting of Door & Room Schedules
rkonik
rkonik
Using Revit 2019 and are working on a multi-story project and have the door schedule sorted by levels.  The door schedule sorts by First Floor, then Second Floor, Third, etc.  The Room Schedule is set the same, to sort by levels, but the Room Schedule sorts Fifth Floor, First Floor, Fourth Floor, Second Floor, Third Floor.  Any ideas why these are not sorting the same?
cbcarch
Check the Filter in the Room Schedule, sort by...…..
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
rkonik
cbcarch, the Room Schedule is set to sort by: Level, then by Number.  The Door Schedule is set to sort by: Level, then by Mark.
cbcarch
Check sorting of room schedule Level is set to ascending.
Cliff B. Collins
rkonik
cbcarch, both schedules are set to ascending, under the level and the mark/ number.
Do you have filters (Filter Tab)?
rkonik
We created a new Room Schedule, and set the sorting and filtering the same as the Door Schedule, and the new Room Schedule now sorts the same as the Door Schedule.  Not sure why the previous Room Schedule was off in the sorting...?
