Sort Rebar schedule based on what sheet they are placed in.
alshammary.l
Observer Observer
alshammary.l
Observer
Observer
Is it possible to sort the rebar schedule into which sheets the rebars are placed in?
I thought of going to each sheet and writing the sheet name into the comment parameter of all the rebars that are placed in the according sheet and then sorting the rebar schedule based on the comment parameter.
Do you guys have another solution that does not require me to manually put a comment into each of the rebars?
Thanks in advance.
"Filter By Sheet" not working?  (under Schedule's Filter Tab)
alshammary.l
Observer
Observer
I think that is a part of Revit 2023. I have Revit 2022 unfortunately... But great to know that someone thought about it at Autodesk! Is there a way to do the same thing in Revit 2022?
