Some text is barely visable
        Hi, I know this has an easy solution, but I can't find it anywhere. Please help. Some of my text is so light its almost unreadable. It is the text like, "Options" and "Exit Revit" under the File tab. This light text is also barely visible under a lot of the VRay Material options. It makes the platform extremely hard to use.
An Example screenshot is attached.
Thank you in advance for your help!
Nick Alexander
MostafaElashmawy
From options goto graphics, check if any of the mentioned colors are set to white.
Mostafa Elashmawy
MostafaElashmawy
I think this is because of the dark theme you are applying.
Please advise if the problem remains when uou make it light.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/H...
Mostafa Elashmawy
ryley.g.h
Update the graphics driver on GPU, restart computer, maybe that will do it?
