Hi. I have recently started working in Revit LT 2023 and creating a model. Everything was okay and all the rooms that are supposed to be cut off by roof ended right under it as they should. But then I worked some more on the model and today when I checked back 2 of the rooms continue through the roof while the rest of them are cut off properly. Only relevant changes to this could be that I have decreased base hight of the roof by 100 mm and changed its slope by 1 degree. Other then that I have just created and added some windows and doors. Does anyone have any inclination about what could be causing these 2 rooms to not be displayed and/or calculated properly ?
Thanks in advance for all the answers.
