Some panels in this curtain system are slightly malformed (Please help)
spongebobdexter
spongebobdexter
It's a warning so if you can live with how they look then just ignore.  Do you want to clean up the million intersection?
spongebobdexter
yes i want to clean up the million intersection, is there a way ?
spongebobdexter
There are several ways:
- adjust the curtain grids a bit so you don't have 3 way intersection.
- model the entire glazing as a window.
- use columns and beams for mullions.
- use a solid mass to cut mullions
spongebobdexter
problem solved ,thank you very much and god bless you
