- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, everyone!
I have just started working in Revit, and I am experiencing some problems with the display settings. So far, I have drawn two concrete column footings using a structural slab and a structural column as elements. As you can see from the plan views in the attachment, level 1 of the plan displays both the column and the slab at the top (gridline B) but only the slab at the bottom (gridline D). Furthermore, I get span direction symbols for the bottom slab only. When I tried placing a column on top of the slab with arrows, I got a warning (see the attached png).
Could someone help me out with organizing the view settings, so that I could see all layers of my levels properly?
Thank you!
