Snapping To angles
Snapping To angles
jfjacques
Message 1 of 8
Snapping To angles
jfjacques
Old problem,
I have snapping on for endpoints - no angle snaps.
I draw a line but can't snap it to the end point because- well I don't ****ing know. Ortho? This happens all the time with tight angles. I just want to snap to the endpoint but no go.
Replies (7)
Message 2 of 8
So what you are saying, is that you can't place a  Angular Dimension period. Is that about the size of it? Nothing at all happens when you press Angular Dimension and pick line A and line B?
Message 3 of 8
jfjacques
No.
I can't place a line exactly top of another slightly angled line. Like say if I wanted to create an area from my plotline.
Message 4 of 8
RobDraw
Have you tried the pick line tool?
Rob
Message 5 of 8
jfjacques
Doesn't work with property line.
Not the point.
Often have a line that just snaps to an angle or despite there being no angle snaps on. Happens with tight angles.
Message 6 of 8
RobDraw
I think that you are going to have to provide an example of what you are trying to do.
Rob
Message 7 of 8
Use TAB.
Message 8 of 8
@jfjacques wrote:
No.
What's a "plotline"?   Sounds like something to do with books or movies.  If you mean Property Lines; the Area is automatically computed.  Select the Property Line and look under its Instance Properties.  The Property Line Area will report in a Tag and a Schedule.   What more do you need?
