Snapping Snaps
Snapping Snaps
LanggamanXavierMassed
Snapping Snaps
I am using rotate and i cannot snap the vertex to a COPLANAR model line, I tried to use a circle center for it but it wasn't working either. no endpoint snap, no midpoint snap. jeez thanks
P.S. snaps is on (snap off is NOT checked)
joe_keogh
Is it possible to place a horizontal Reference plane at the point you want to rotate from and Snap Intersect?
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
i tried to put a reference plane along the level it's set but still, it's lacking snaps... i set the reference plane in all the views and still nothing.
joe_keogh
I see, try this
  1. select the element you want to Rotate
  2. type "RO" to start the rotate command
  3. tap the <Space Bar> to move the axis of rotation to your Cursor
  4. with the cursor Place the Axis of Rotation where you want it
  5. click in white space to begin rotating the element
  6. type the Angle of rotation
Step 3 is the tricky one I think?
Joe Keogh
thank you! I tried to do number 3, sir, but it only make error sounds and i don't see any change.
What's your current workplane? I see you are in a Massing environment.  We can probably help better by seeing the file. Want to post it?
...but if I had to only guess, I'd say your Current Workplane is the wrong workplane to be in to perform that action.
