Small increments - problem in sketch mode
3 REPLIES 3
323 Views, 3 Replies
Hello, I am facing a problem when drafting in sketch mode a Filled Region. I should make a trapeze with longer border ( left hand) 2,37 m long, shorter border (right hand) 2,32 m long, difference about 5 cm. When drawing the right hand the cursor jumps to either 2,37 ( draft 1, straight rectangle) or smaller increments such as 2,30..2,02 ( draft 2).but not desired length. Turning snaps off seems no solution. Thank you, Dan
3 REPLIES 3
As far as my understanding from your description about your problem that the distance 5cm is very short. In Ravit this type of smaller measurement you will not be able to sketched. Better you take measurement from 1. One confusion i have found that your other measurement is in Metre but you are saying that the difference is only 5 cm!!!!!!!!!!!!!!
Otherwise, please send me your Revit file or send me some images, so that i can understand that what you are asking for.
Thanks & regards,
Subhradeep Sen
Kolkata
India
Thanks & regards,
Subhradeep Sen
Kolkata
India
As i told, the difference between 2,37 m and 2,32 m is 0,05 m = 5 centimeter. Regards, Dan
OK. LET ME SEE TOMORROW MORNING.
SUBHRADEEP SEN
SUBHRADEEP SEN
