Sloped wall with curtainwall.
cgullettUSWBQ
cgullettUSWBQ
What is best way to create a sloped wall containing a curtainwall.   I had originally modeled it as vertical and tried to slope it using the properties window.   Now the curtainwall is embedded in the sloped wall.   Is there a way to edit the profile of the wall using a work plane?
Thanks!
Sloped Glazing.
Roof.
Help | About Roofs | Autodesk
I'm assuming you don't have Cross-Section Definition Properties in the Wall Properties.
Help | Place a Slanted Wall | Autodesk
syman2000
The other method is create slope massing and apply the curtain system by face.
cgullettUSWBQ
Thanks.....I ended up editing the solid wall's profile while it was vertical and rotating the wall and the curtainwall separately in the properties box.   Actually worked out really well!
Edit Profile?  So, you're not using System Family Basic Walls then. Why not?
