Sloped wall as room boundary
MiWolff
Mentor Mentor
MiWolff
For a small in-house tutorial I just modelled a wall with a slope. According to an old entry in this forum, I did that making an in-place component of the category wall. Inside the component editor I entered a sweep with my slope sketched into the profile. I made sure the new 'wall' was tagged as room boundary and removed the former standard wall. The room behind the old did not adopt to the new wall but simply cannot find its boundaries anymore. What am I to do?
room intactroom intactstraight wall to be erasedstraight wall to be erasedroom brokenroom brokensloped wall does not provide boundarysloped wall does not provide boundary
Hi, @MiWolff
That You Need? it's work fine, check the attached image or you can provide room boundary line as well.
if possible attach the tutorial file for future assistance.
Please click " Accept as Solution" on the posts that helped you, so others in the community can find them easily.
MiWolff
I'm afraid that is not quite what I meant. The room's boundary in your image is not sloped. How did you tilt the wall in your example?
I would have thought sloped boundaries were quite normal in Revit given the shapes of the building in the splash screen:
 organic hadid like splash screen buildingorganic hadid like splash screen building
MiWolff
The tut is a rendition of the old 'draw a house with a single line doodle'.
Best way to place a Room in that situations is to create the Room from above with a negative base offset.  You may need to use Room Separation lines to create a boundary on the originating Level.
MiWolff
One more thing: When I tried the sloped wall in R2017 it did not work as a room boundary, using R2020 it was accepted perfectly well. The work-around given by barthbradley is still necessary to get sloped rooms.
@MiWolff you can tilt the wall using wall by mass or draw as wall component as you did in your file. @barthbradley regarding the room volume still found some weakness to get actual room volume. Check the attached images.
Anybody have idea about any Revit plugin, who gives us correct volume and form of a non-symmetric room.
