Sloped floor plan not displaying correctly
AbbyCZQ26
Message 1 of 24
AbbyCZQ26
I am modeling a skybridge that is ramped. I have created a floor plan of the bridge, but because the cut plane of the floor plan is flat and the bridge is sloped, the plan is not displaying correctly (see attached). Is there a way to angle the cut plane so it reads correctly?
I have already tried using a section view, but it caused a problem with annotations and still wasn't reading right.
Replies (23)
Message 2 of 24
rxi.gg
I think you'll have to use sections. What problem do you have with the annotations?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Message 3 of 24
AbbyCZQ26
When I use a section, the view isn't in the correct orientation. I can rotate the view, but then the annotations all appear upside-down.
Message 4 of 24
I don't know what you mean by it "is not displaying correctly" in Plan View, but if you want a View that is parallel to the sloped surface, then you can create one with a Section.
...are you meaning that the Plan View View Range doesn't capture all of the sloped floor.  Raise the View Range Cut Plane then.
Message 5 of 24
What annotations?  Annotations are View-Specific.  Are you saying Annos are showing upside-down when you place them in the View?
Message 6 of 24
AbbyCZQ26
The section view that I create is showing vertical, but I need it to be horizontal on the sheet. I can rotate the viewport on the sheet, but then the annotations rotate with it and are sideways (text and dimensions).
Changing the view depth doesn't work because it will still show parts of the wall. I need it to be cutting through at the glazing, all the way across.
Message 7 of 24
Did you Rotate the Section Marker?
Message 8 of 24
See attached.
Message 9 of 24
Message 10 of 24
I think I know what you are talking about regarding upside-down annos now.  Instead of rotating the View on the Sheet, activate the View and Rotate the Crop Boundary.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-D...
Message 11 of 24
AbbyCZQ26
I tried that also, but instead of rotating the entire plan, it just rotates the crop box itself and the plan is left in the same orientation. Unless I'm doing that wrong. Just selecting the crop boundary within the view and then using the rotate command, correct?
Message 12 of 24
@AbbyCZQ26
See screencast below on how to rotate the viewport.
Create a detail callout in the sloped section view, then open the callout view and rotate the view crop region.
Message 13 of 24
Hmm... are you sure you are actually rotating the plan view crop boundary?
Did you look at the Link I posted?
Message 14 of 24
AbbyCZQ26
Yes, I am using the rotate tool to rotate the crop boundary, like in your link. See attached, when I rotate the crop boundary, the view doesn't respond to it.
Message 15 of 24
Message 16 of 24
AbbyCZQ26
In the screenshots, the crop box is rotated but the plan view is still vertical. I found a solution though, creating a callout allows you to rotate the actual view as well. Thanks for the help!
Message 17 of 24
Did you edit crop and rotate it? Rotate the crop. Don't edit and rotate the sketch boundary. Just like in the Link.
Message 18 of 24
Never mind. I don't want to help you anymore. @ToanDN will just repackage what I say, and you'll give him the credit.
Message 19 of 24
AbbyCZQ26
Sorry for any confusion. I rotated the crop (not edit and rotate the sketch boundary), like you said, but that didn't work, as shown in the above screenshots. I assume this is because it is a section view and is unable to be rotated, but not sure. However, I made a callout on the section view and the rotated its crop (like suggested by @ToanDN), and I had success. Again, thank you for the help.
Message 20 of 24
That's not correct.  You can rotate Section Views all day long and twice on Sundays.
Maybe @ToanDN can post a Screencast.
