Sloped & Tapered Wall
119348566
Message 1 of 11
119348566
How would I model a Tapered wall that stays flat at the top but the base varies from 4.5m to 6m deep? Any help is appreciated
Replies (10)
Message 2 of 11
Do you mean the base has different thicknesses or different elevations?
Message 3 of 11
119348566
Different elevations
Message 4 of 11
Then model a normal tapered wall and attach it's base to the sloped slab. If you don't have a sloped slab, edit the wall profile, or draw a sloped ref plane and attach the wall base to it.
Message 5 of 11
119348566
Is there any chance you could show me some step by step? Im not familiar with how to attach to the bottom
Message 6 of 11
Select the wall, click Attach Top/Base button on the Ribbon, choose Attach Base, select the sloped slab at base
Message 7 of 11
119348566
By creating a sloped ref plane and adding the base of the wall to it would it stretch the wall downwards until it came into contact with that slope of the plane?
Message 8 of 11
No. You don't have to stretch anything.  Use Attach Top/Base to attach the wall base to the plane.
And I just looked at your picture, you clearly have a sloped slab then just attach the wall base to the slab.
Message 9 of 11
119348566
Alright that makes sense, Thanks a lot!
Message 10 of 11
119348566
Ive come across an addition to this problem, how would i attach the base of the wall to extend below the slab rather than stop at the top of the slab?
Message 11 of 11
Go to an elevation, draw a ref plane at the bottom of the slab, attach the wall base to it.
