SLightly sloped roof with different edges
7 REPLIES 7
Message 1 of 8
hve-architecten
421 Views, 7 Replies
Justed wanted to share something:
I was working on a roof with some slight slopes for the water drainage to 1 or 2 sides.
Normally you use the "modify sub elements" in oder to create height differences. But then every corner gets a line drawn from point to point. Very annoying.
There is a workaround:
-Draw a flat roof.
-Create a slope on the top with modify sub elements. Say one side is +50mm, the other is -50mm.
-Create in floorplan view a component-in-place void-extrusion and cuth the void of the roof before closing the component family.
Tags (1)
Labels (1)
7 REPLIES 7
Message 2 of 8
Sketch the Floor perfectly square, slope it as required and then use an In-Place Void to cut the Floor to it's shape.
Message 3 of 8
in reply to: hve-architecten
You can do it with just a single roof.  Same as @barthbradley suggested, except I would use Vertical Opening Cut tool instead of an in-place void.
Message 4 of 8
kchristol
in reply to: ToanDN
Why so?
Message 5 of 8
in reply to: kchristol
@kchristol wrote:
Why so?
Why so what?  Why model it as one roof instead of 2 or why use Vertical Cut Opening instead of void?
Message 6 of 8
kchristol
in reply to: ToanDN
vertical cut opening instead of void.
Message 7 of 8
No in place model.  No cut geometry.  So, fewer steps with the same result.
Message 8 of 8
kchristol
in reply to: ToanDN
Good points! Thanks for the tip!
