Solved by barthbradley. Go to Solution.
Solved by ennujozlagam. Go to Solution.
yes see this. thank
https://www.youtube.com/watch?v=3pQep4q3360
you can download sliding door HERE or create your own sliding door family and change the panel of your curtain panel with sliding door. thanks
You could also use copies of the OOTB "Door-Curtain-Wall-Single-Glass" with different Offsets.
