Slanted Wall with Edited Profile in Revit LT
BigPicture045
Message 1 of 11
BigPicture045
See the slanted wall below:
Now view it from an angle:
I need to edit the profile of this wall so that it has a similar angle as the columns you see next to it. I need it to be like this when viewing it from the side elevation:
However, when adding a slant to a wall with an edited profile I am getting the following message that does not allow me to do this:
I am using Revit LT.
Replies (10)
Message 2 of 11
I've never encountered that error.  The Profile is doable though. Do you have all four sketch lines?
Message 3 of 11
BigPicture045
@barthbradley Just verifying, once you edit the wall profile, are you able to add a slant to it?
Message 4 of 11
Yah...and attach it to a roof afterwards via the Attach Top/Base tool.
Message 5 of 11
here's the Profile for that wall:
Message 6 of 11
BigPicture045
@barthbradley
See the video below for replicating the error message and for the workaround I used.
Edit: How do I get the embedded video to work here?
https://autode.sk/2KM9mAF
Message 7 of 11
Ah! 2021 Slanted Wall!  I see now what you are trying to do? I can't do it either.
What about Cutting the Angle with an In-Place Void?
Message 8 of 11
Message 9 of 11
BigPicture045
I don't believe in-place void is available in Revit LT.
Message 10 of 11
Model the Void in a Family then.  Check "Cuts With Void When Loaded".
Message 11 of 11
Smart workaround though.  😉
