Slanted Wall with Curtain Wall
zs-17
zs-17
I have a curtain wall inside w wall. Both are ave curved shape. They work properly when they are vertical. But when they are slanted, the opening automatically transferred to filled (or solid). The cut Geometry option can't cit the wall. How do I fix it? The wall Opening works with me, but  I prefer not to use it if possible.
You might want do your Curtain Wall as  a Divided Surface with Pattern-Based Panels.  You can try a Curtain System or Sloped Glazing on Mass Surface, but I'm afraid it won't follow the conical surface the way you want.
...maybe I'm misreading screenshot. Toggle your Pattern button.
zs-17
I will try it all and see which way works better in my conditions.
Many thanks
I have the same problem. Have you fix it?
sarahP4C2T
Observer
Observer
I also have this problem. Did anyone find a fix, or alternate solution?
