Revit - Trusses in family are causing dotted lines to be larger than the family
rbuentgen
Observer Observer
rbuentgen
Observer
Observer
Good day, I am creating floors and for some reason revit thinks my trusses are larger than they are. I have changed the properties to what they should be but they remain larger than they are. This is causing bleeding into other sheets and messing up my truss count. Any help will be appreciated.
This is the wrong truss as you can see the dotted lines are much bigger than the truss and the truss is the only thing in the family.
Here is an example of how is should be where the dotted line is only around the truss.
Thank you all for you help.
This post has been edited due to: @heather_tracy added the product to the title to help more community members find this topic.
jay_colc
That looks like a Group Boundary Dotted Line is there anything else that may be inside that group?
What Truss Family are you using out of reference?
Jay Colcombe
Autodesk Certified Instructor
heather_tracy
Hi @rbuentgen,
I wanted to check in and see if you saw @jay_colc's follow up questions and you still needed assistance, or if you found a solution to your question already? Please share any available screenshots or screen recordings so the community can assist you further.
All the best,
Heather | Community Manager
