- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is it possible to slant a wall at 45 degrees, but set the rotation axis to be curved (red dotted line in images below). I have created a roof structure using model in place, creating a sweep and then a series of void extrusions. I am now trying to create the skylight structure above by creating a curtain wall which I can then rotate 45 degrees along the curve of the roof. Please see images attached. The issue is that when I rotate the wall the plane by which it rotates is flat rather than being able to choose a curve. I wondered if there was a way to set the rotation plane along a curve.
Fin
