Slab part hatch
Slab part hatch
Slab part hatch
Hi Good day,
I'm currently working on a project with involves making a material legend for my floor.
The way I did was making a 10mm slab on top of my current slab then dividing it into parts and putting up a material in every parts.
I made also a template, which I named OVERALL (1:350, course) and PUBLISH (1:50, course)
I made the parts in my Overall plan, my problem is that the parts with hatch doesn't show up in my Publish plan.
Just for experiment I tried making my PUBLISH drawings in to a OVERALL template but still it doesn't show up the parts with hatch.
I also tried making some callout to check the detail but still it failed to show up.
Thank you in adavance.
Lower the view range bottom a bit.
Actually my Overall & Publish have the same view range. I can select the slab but I cannot select the parts in publish.
You can see but you cannot Parts in Publish view? Or you cannot see Parts altogether? Is the view set to show Parts, or show both Original and Parts?
Just checked my visibility graphic the parts are turned off at the Publish template.
Never thought it has a category,
Thanks sir ToanDN
