- Mute
- Permalink
- Report
Good morning,
I would like to draw the slab edge inclined, how to do this? The Revit present this support? Thanks
Good morning,
which edge??
1. the top edge so it will be a tapered entry at the portal?
2. bottom edge so it will be a thickened slab?
3. leading edge so it will look funky?
to draw curb on an inclined slab.
that wasnt one of the options..... 🙂
if you want it in 3d, you can made the entire slab the full thickness of slab plus curb... then create a void to shape the curb, cutting the rest out.
or.. you could create the slab as a sweep with the curb profile built into the profile...
or you could make the slab... and then add the curb as a sweep of its own.
if you want it in 2d only... then just use a fill region on the section drawing...
Are you trying to put a slab edge on the sloping side of a sloped slab? Make the slab horizontal, apply edges and slope again. Edges will follow.
ok, thanks for the answer, in another case, what do you suggest for inclination of this drainage channel?
The sweep is limited because it does not make angled turns with straight lines (long paths) and by family of metric profile there is no possibility of inclination.
Why doesn't your drainage channel slope? Want one the does?
because I don't want draw a slab for a inclination, no necessary
I'm not understanding the drawing. What am I looking at?
It's a traced of road
are you trying to model a curb and gutter?
@Marielen_ wrote:Yes, but there is no gutter, just curb and natural terrain and after that, a drainage channel.
Natural terrain? Are you working with a Revit Toposurface?
@Marielen_ wrote:yes
TMI. 😏
Hey, I have no idea what you are doing or how you are doing it, but it sounds like you are trying to get hardscape to follow Toposuface. This is how I roll when doing that...
@Marielen_ wrote:
Good morning,
I work in a company that wants to implement the 3D model for drainage and
highways, but encountering many difficulties with REVIT, do you think there
is another program or do you think this is the best option?
1. What does your company do?
2. What difficulties are you experiencing with Revit?
