I'm working in Revit Architecture 2020 for the Arch Construction Docs for a commercial office space. Throughout the office there will be data/phone plugs next to a duplex. I can't find a data nor data/phone combo to load into the project!
Does anyone have any suggestions on creating or loading?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von !Dalton_Goodwin!. Gehe zur Lösung
Gelöst von rendermaster. Gehe zur Lösung
Here's one from the OOTB Library. You can change the label to read whatever. For instance, "DP" for Data/Phone.
or create / modify one:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
or check this, Multiline Phone
https://www.bimobject.com/en/seps2bim/product/a1015
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
There is a OOTB Data family. You could also nest a phone and data family into a newly created family. Just make sure to check the "Shared" checkbox in the Family Category and Parameters family setting.
Thanks for yours and everyone's response and help, I really appreciate it!
I've seen that Data_Communications when I was searching, but the preview only was showing the TV symbol so I didn't load it! I was looking for a Data/Phone symbol similar to the CAD symbol! Is there a way to create a combo like this below? That way I can simply place this in the project versus individual families.
*I tried to insert screenshot JPEG & PNG but it's not showing!*
I did, and it wasn't uploading JPEG or PNG files. I screenshot and Ctrl + C'd into Paint and saved. I will do it again in this comment.Is this Data/Phone combo possible to make in Revit? Just curious
