Slab edge and multi-component floor
Rvt 2016 - I'm trying to create a simple footing around the perimeter of a floor.  Using slab edge to try to accomplish this.  The floor has the concrete component and a sand component.  The slab edge profile is not cutting the sand.  I tried the join tool, but that doesn't work.  I'm not sure what I am doing wrong.  I had thought I had done this in a previous project a couple years ago but I don't have access to those files anymore.  I have attached pictures of what I am getting along with the profile I created.
Hi, you might want to try to enter a negative value for the 'horizontal profile offset position' of the footing so it is placed on the outside of the floor edge and not internal.
