Topo - Create from import or not
2 ANTWORTEN 2
Nachricht 1 von 3
245 Aufrufe, 2 Antworten
Hello. I am starting a new project and I would like to discuss with you mates either it is more advantageous to create a separate topo file and import into the project or..
Create the topography at site plan..
Help appreciated, thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
When I meant create from import I meant to link a RVT with the topography
Nachricht 3 von 3
constantin.stroescu
I can say how I usually do it.
  •  I prefer doing the terrain and the exterior facilities on a separate file.
    • if there are more than one building , I use this file( with the site ) as host for the other files that contains the buildings - I use shared coordinates published from the  site file to building files.
    • If there is only one building and the site is only something small around, then I prefer to link the site file into the building file
  •  sometimes for small projects I 'm doing everything in one file
Constantin Stroescu
