SKP file disappearing when scaled up
StephaniePhillips2269
Message 1 of 9
Got a issue importing a SKP file, Has imported correctly and is showing both in 3d and 2d floor plans but is scaled incorrectly and when scaled up it disappears. How do i scale it without it disappearing ?
Replies (8)
Message 2 of 9
How are you scaling it?
Message 3 of 9
Have scaled multiple ways but it almost seams that as soon as it gets bigger that the box it imports in it disappears
Message 4 of 9
Multiple ways?  What ways? I can only think of two ways, right off hand.
Message 5 of 9
Have scaled through Modify scale tool and through type property changing the import scale
Message 6 of 9
What Scale Factor are you entering?
Message 7 of 9
Let us have a look at the SKP.
Message 8 of 9
it says scaled 1:1mm when imported but is actually 1:1000 and when changed to be correct units and scale factor it dissaspaires out of the import scope box
Message 9 of 9
So your are basically describing this?:
Before:
After:
