Skipping a release of Revit
freelancette
freelancette
Hello all,
Simple question ... I was not using Revit for a period of time and have now gotten back to it.  Have been using 2021 for eight months or so, but never installed 2022.  Can I go directly to the 2023 version without installing 2022 or is that not considered a good practice from a technical point of view?
Robin
Should be okay. Archive original models prior to updating to the new version.
freelancette
Thank you!
I presume this is more about upgrading models from previous versions.  Sequential upgrading is recommended, but frankly we've never had an issue that I can recall.  Upgrading legacy projects non-sequentially is pretty common for us.
HVAC-Novice
Maybe in theory upgrading a project from one year to the next is recommended.... but I never go through all my old projects and upgrade them. If I need to open a 5 year old project, I never had a problem.
I know families are simpler. But many families I download somewhere are 8 year old versions and it usually isn't a problem.
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
freelancette
Thank you all for the input.  I, too, have upgraded projects from (10+?) years ago without the sequential process and have never had a major issue.  Sometimes a minor warning, but nothing significant.  I guess I was more worried about some sort of internal coding issue related to the Revit program files already on my computer, but it seems that's not a concern.
Thanks for the reassurances !!!
