sketchup into revit 2020
Is there any way to import sketchup model or family into revit 2020?
With materials and softer ?
aRcHiTeCt.JM
… hi @Anonymous
… go to
…. https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revi...
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
thank you now I can export to revit but I can't manage materials. Is there a way to change the parameters for materials as well?
Look under your Object Styles for Imported Categories.
thank you, but that is in revit or in sketchup?
everything I'm importing is getting grey and with lots of lines around.
is there any way to softer the elements?
In Revit.
There is a category under object styles for imported objects.  The Sketchup model should be listed there.  You can override the materials.
Note that it depends on how the Sketchup was modelled - the layers in sketchup need to be properly setup as categories to get the desired results.
I will be trying, its not totally clear. thank you
is there any way that you can send me a family imported from sketchup that I can play around changing materials
just to see how its done?
