- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there
Im having issues with the importing sketchup file into Revit. So I imported sketchup file into Revit however the model's building parts are all over the place if you look at this image, it is not solid. Looking to know what could be causing this. When I open the file via sketchup everything appears clean and not is sticking out, so I dont know if it is a revit issue in this case
