Civil engineers either use, (if we're focused on Autodesk products) AutoCAD or Civil 3D, which is the product Autodesk believes is the correct choice for them. I am aware that some firms (very small proportion I believe) use Revit in some fashion too.
AutoCAD technically isn't any better suited to the task because it is a general purpose drafting tool. You can draw things representing molecular biology, ships, or a dishwasher...in 2D or 3D. I learned AutoCAD first and I thought it was an awesome program back then. It took a bloody long time to master. Then I used some other products and noticed the contrasting approach each one took to solve the same problems. You can draw anything in Revit too. It has a bias toward building elements though. If you're only ever going to draw 2D lines it's probably not worth the effort to switch.
It's true that Revit doesn't have a polyline, but a series of lines can be manipulated like one. In Revit I use toposurface to generate contours instead of drawing lines. Usually I create it from the work (DWG usually) of a surveyor. Then again I've seen people twist railings into representing a variety of things, other than a railing, that a polyline might be used for.
Revit approaches tasks differently because it was designed by different people than AutoCAD (different company originally too) and because it set out to solve the problem of drafting differently too. Also once we master a software program we usually find it's possible to accomplish things that, initially, seemed impossible.
If you are a civil engineer then you ought to be examining all the products that claim to suit your profession and decide which one fits your work best. Revit could be a good fit just because it may help you work with clients that also use Revit. Then again you might find Civil 3D is better suited because it helps you deal with engineering problems Revit ignores, like road alignments or hydrology. If you do landscaping Revit might actually be a good fit, check out Laura's blog.
Steve Stafford
