Site Plan Arc Is backwards
Message 1 of 12
This is the first site plan I've done and I can't quite get things to line up. Two of my arcs I believe are backward and the border doesn't quite meet back up at the end. I had to mess with some of the directions of the lines to even get them to look like they do on the original plat. Anyone have any suggestions or know what I'm doing wrong?
Replies (11)
Message 2 of 12
Reverse calls. Happens all the time.  Just Edit the Table and change the direction the line is going (e.g. North to South, East to West).
Message 3 of 12
When I do that it just messes everything up.
Message 4 of 12
Give me the bearings for the front and rear property lines.
Message 5 of 12
Are those not in the screenshot I sent of the plat?
Message 6 of 12
Never mind. I missed that info on the plat.
Message 7 of 12
So is it messed up because I did plat 14a and 14b with no separation in the middle?
Message 8 of 12
Did you use the above table?
Duplicate what I'm showing in Message 6.
Message 9 of 12
Message 10 of 12
I figured it out it. There's an option for left or right-handed arc and I had facing right
Message 11 of 12
ARRGH!  I just realized you were doing 14B -- not 14A, which I did for you. I counted 6 line segments in your screenshot, so I assumed your lot boundary was supposed to be 14A, since 14B has only 5 line segments.  How the heck did you get 6?
Message 12 of 12
It's a duplex lot so I'm actually doing 14a and 14b together.
