site image material is mirrored on topography
jasonmazis
Message 1 of 16
jasonmazis
I have created a topography and I keep trying to put an aerial view image of the site from google earth as  the material.  But whatever image i place on the site become inverted or mirrored when on the texture.
jasonmazis_0-1654712893320.pngbelow is the image
 Any help is appreciated as this fairly urgent.
Thank you
Replies (15)
Message 2 of 16
How are you applying the Material?  That is, what element is using it?
Message 3 of 16
GustavoUbriaco
Hi
what happens when you rotate the material?
Gustavo Ubriaco Contreras
Message 4 of 16
jasonmazis
It flips in other directions  no matter which way i rotate it it will not match the original
Message 5 of 16
jasonmazis
topography- | first duplicated the site material which was grass and changed it. ten I made a new material
Message 6 of 16
Did you uncheck Bump and other Images?
Message 7 of 16
jasonmazis
yes all unchecked
Message 8 of 16
jasonmazis
would it be possible to do a team viewer or anydesk
Message 9 of 16
Are you sure it's being inverted and not just oriented to True North?
Message 10 of 16
Just post the RVT along with the PNG and we'll test.
But for the life of me, I can't even get a PNG to invert no matter how hard I try.
Message 11 of 16
jasonmazis
It comes in as an exact mirror
Message 12 of 16
Mirrored or inverted?  Two different things.
Just post your two files as I suggested above.  Otherwise, it's just a guessing game.
Message 13 of 16
GustavoUbriaco
I think this happens because the topography is an irregular shape
try to edit that topo surface to make it rectangular.
then te scale have to be the same, this is only an example
Message 14 of 16
As a test, apply the same material on a floor and see if it comes out correct.
Message 15 of 16
Try rotating the image slightly 0.1 degree.
Message 16 of 16
jasonmazis
Hi with a whole host of rotating and a mirror of the image in Photoshop I seem to have got the correct angle no I am just trying to resize it accurately thank you for your help.
