Site Designer - Imports topo with a strange elevation
SteveDFThorne
SteveDFThorne
Tried to import landxml topo with site designer and it placed the surface way down at - 16579396.94. This number is similiar to my y coordinate of the survey point but with a negative value. I'm using Revit 2016. Is this a glicth? This used to work.
Kimtaurus
As far as I've experienced, Site Designer isn't working correctly in R2016. Others are experiencing problems as wel (just check the forum).
My best guess is to wait for an update of Site Designer (I know I'm not offering a lot of help).
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Alaaeldin_Alsahli
It is could be a defect in 2016 but to narrow down the issue, is it possible to give it a try in 2015 and see if this works well?
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Alaaeldin_Alsahli
I wanted to follow up to see if you were able to gather the information I had requested to assist in helping further troubleshoot your issue.
Alaaeldin Alsahli
SteveDFThorne
I would like to but at the moment I don't have the time. I will give it a try soon though. Thanks
