Silent install Revit 2020 - could not access network location
luan.doanT6NLT
Observer Observer
luan.doanT6NLT
Observer
Observer
Trying to make a Revit package for Intune.
Before uploading, I'm testing the application through Command-line: Setup.exe /W /q /I .\Setup.ini /language en-us
Receiving the event viewer error: Product: Revit 2020 - - Error 1606.Could not access network location Revit 2020\.
I've already googled it, and there is no folder redirection and registry is fine + it's a clean install, so there are no remants of previous versions.
Also tried parameter /t.
Installing revit by just clicking the setup.exe works.
Installing a deployment package works, but Intune can't access the server share...
Any ideas?
omushahwar
I am working on 2020 deployment myself, 2022 and 2024 had no issues.
One thing we have done is make a Revit deployment that targets the C:\Autodesk folder then we package it all up in an intune package so its placed there by intune (You can contact microsoft to increase package size from 8gb to 32gb)
We can get the files there no problem but all the ways we have tried to run the install lock up.  Happy to share details as we work through options now.
One suggestion on another post was create a scheduled task that would run it vs having intune run the install. Havent tried it yet but will soon.
