Signage with multiple lines of text, each line have a multitext parameter
carlosSSD9T
carlosSSD9T
I want to design a post and panel sign, each panel will have a destination with an arrow pointing in different directions. For some reason, I cannot change the text on the properties panel. I will do appreciate your help. (uploaded Revit family for reference). Thank you
EATREVITPOOPCAD
You made the text a type parameter instead of instance. so to change the text in your scenario you would have to click edit type in properties
To be able to change the text in properties it must be an instance. I re-uploaded the family with instance text parameter for you 😉
The definition of insanity is doing the same thing over and over again and expecting different results
carlosSSD9T
AWESOME! Thank you so much, happy weekend! 😀
EATREVITPOOPCAD
Glad could help! happy weekend
