showing level in 3d view?
Message 1 of 14
How to show the levels in 3d view for presentation? I am using Revit 2014. thanks a lot.
Replies (13)
Message 2 of 14
ennujozlagam
Open a 3D view>hit the little down arrow on the view cube>orient to view>Plans>(use desired plan)>adjust the view to appropriate angle(as it will appear in plan; though actually 3D and cut at the plan view's cut plane)>Save View as another name: rinse, repeat...repeat..hope it helps, thanks
Message 3 of 14
loboarch
Level datums are not able to be made visible in a 3d view.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 4 of 14
cbcarch
In Project Vasari, you could display Levels in 3D, as in the Conceptual Massing Environment in Revit.
Perhaps you could use Masses for the presentation and have the Levels show in 3D?
Please post an example of what you are trying to do--and/or give us a little better/more information.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 5 of 14
Alisder.Brown
talent909
You have two options. You can simply model a floor (one that is like 5mm thick) to represent a level plane and make it transparent or you can create some kind of line based family to do the same thing. It cannot be done by default but both the options above work fairly easy 🙂
Hope this helps 🙂
Alisder Brown
Senior BIM Coordinator
Scotland, UK
Message 6 of 14
cbcarch
In the Massing Tools, you can display Levels in a 3D View.
See attached.
Cliff B. Collins
Message 7 of 14
constantin.stroescu
try to use Mass Floors :
  • create first a Mass Element that envelopes the building , then create Mass Floors and finally Hide the Mass Element..Mass Floors being conected with Levels they will move with them, when changing Level heights...
Constantin Stroescu
Message 8 of 14
cbcarch
Question for the original poster--please clarify:
Are you wanting to show the Level Annotations? or the actual Levels ( like floors that are colored, as shown in the post above?)
Cliff B. Collins
Message 9 of 14
constantin.stroescu
the screencast shows the steps...
Constantin Stroescu
Message 10 of 14
cbcarch
Good solution, IF that is what the question was.....
I was trying to find out if the OP meant Level Annotations showing in 3d views, like in the Massing environment.
Cliff B. Collins
Message 11 of 14
constantin.stroescu
I understand what you say ......maybe a workaround could be possible if  we export the 3d volume as .dwg and then import (without to open it in AutoCAD) it back into Mass editor....
Constantin Stroescu
Message 12 of 14
cbcarch
Yes--this is a workaround but it can work.
I put "Levels in 3D Views" on the Revitforum.org Revit Wishlist some time ago.
Seems like if it works in Massing Environment the Factory could also make it available in "normal" Revit 3D Views as well.......
Cliff B. Collins
Message 13 of 14
maryko
Congrats, Autodesk has added this feature in Revit 2019. Although you can do that in previous versions by using dynamo as described in video below:
https://www.youtube.com/watch?v=Kt2QmfTlE-0
Message 14 of 14
Viveka_CD
Hi @maryko, @Anonymous
Thanks for the wishes! The team will be happy to hear this.
Please see AKN article: About Levels in 3D Views
