Showing a 2D element instead a 3D element in a plan
yoel_jaimes72LNQ
Message 1 of 10
yoel_jaimes72LNQ
Hi community!
Currently I am using Revit (2025) and I am trying to create a special view of every element I have in 3D for a simpler one 2D.
I am modelling a railway station. I have for example a Drainage shaft which sees like in Picture 1. And I will like to show in my plans just a simple circle with an X in the middle.
I have seen here I have to draw the lines inside the family and somehow associate them with the visibility but I don´t understand how. Could someone please explain me?
Kind regards,
Yoel
Picture 1 - Drainage shaft in 2DPicture 1 - Drainage shaft in 2D
Accepted solutions (3)
Replies (9)
Message 2 of 10
RDAOU
@yoel_jaimes72LNQ
You place symbolic lines in the family (circle). Then you select the 3D element(s) and edit their visibility settings >>> Uncheck the box for show in Plan/RCP
This will stop the 3D from displaying in those views (Plan and RCP) and the 2D will show instead
You can apply the same princp. for Left and Right views
Message 3 of 10
yoel_jaimes72LNQ
Hi Rdaou,
thank you for your quick reply. I did as you said but the lines as symbolic lines don´t appear in 2D or 3D.
And when I create them as model lines even though I change the visibilty options they keep appearing in the 3D model. (As well in the 2D plan)
Message 4 of 10
RDAOU
@yoel_jaimes72LNQ
upload the family you are working on...easier to show you how than explaining
Message 5 of 10
yoel_jaimes72LNQ
Hi. It is uploaded. Thanks!
Message 6 of 10
RDAOU
@yoel_jaimes72LNQ
See GIF below
  1. Open Family
  2. Select everything
  3. Use Selection filter and uncheck the line and Keep only the Generic Models
  4. On the properties panel edit visibility settings and uncheck Plan/RCP
  5. Save and reload into the model
Message 7 of 10
yoel_jaimes72LNQ
Thank you!
It worked! It works perfectly when I start a new project. But I dont know why it doesn´t seems to work for an existing project. I even copied the platform I had from my existing project to a new one and I still cannot make it work somehow.
Attached are the screenshots and the model to see if you have any idea why.
3D View
Plan view 1
Plan view 2.
At the beggining i though it was because the floor is irregular, but I created a new irregular floor and it still works so I don´t understand
Thank you for your help!
Message 8 of 10
yoel_jaimes72LNQ
Attached the model
Message 9 of 10
RDAOU
@yoel_jaimes72LNQ
It works but you are not seeing it  because there is a floor on the max_Bahnsteigoberkante Ebene which is blocking it. You are placing it on the level below so to say.
Message 10 of 10
yoel_jaimes72LNQ
Thank you!
