Show Detail Groups in Linked View
abranzCCVUF
abranzCCVUF
I am using a linked view from a model that includes a filled region that has been put into a detail group. Even when setting the model in V/G Overrides to Linked View for everything, the filled region still will not appear in the view. Is there a way to get the filled region to show while in the detail group?
handjonathan
Hi @abranzCCVUF
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
aaron_canubasR7REF
Observer
Observer
Avoid ticking/checking on the Underlay settings of the Revit links.
