I can make this roof in Sketchup, and I know I can bring that into Revit and do a "Roof by face"... but does anyone know how to make this roof in Revit? I know I can clip the corners off by using a vertical opening, but how to slope the ridge line with it still being a gable? Raising one eave of the gable end didn't work.
Solved by barthbradley. Go to Solution.
Solved by constantin.stroescu. Go to Solution.
Roof by Mass Face is one approach.
Got full Revit? Another would be to Shape edit a flat Roof with Modify Sub-Elements Tool.
Here's an exaggerated example of your "Ship's Prow" using Roof and Modify Sub-Elements:
This is great! I didn't know you could use multiple slope arrows on the same roof plane to control the slopes like that! Brilliant!
JP
I didn't know you could do that either. Still, how would control the slope and pitch? Seems difficult and impossible. I can play around with slope arrow's slope to get the front-to-rear slope near dead-on-ballz accurate, but I can't find a way to change the pitch from eave to ridge with this method.
School me @constantin.stroescu.
I see that per Constantin's screen cast that the closer you move the tails of the slope arrows toward the end of the roof they are pointing to, the steeper <edit, they approach> the designated side-to-side pitch... however, as you note it's a bit soft on exact slope. I know it may not be best practice, but for now I got it eyeball close and rounded off the units of the slope arrows and it gets it done. I would like to know a more exact method for this because otherwise it's really easy and avoids the nightmare of getting walls to attach to roof-by-face objects.
Your discovery is my discovery. There doesn't seem to be any control using this method. It's cool though.
I would just use Modify Sub-Elements myself.
as a comparation you can see how can the same thing be done using Roof by Footprint with Slopes cut by Voids.
and the geometric explanation:
with Voids - the same result>>
Constantin Stroescu
