Sheets missing from Autodesk drive
anat
anat
When opening a Revit file in Autodesk Drive, and selecting 'view in Browser' not all sheets are appearing.
Some are missing. Anyone knows why its happening?
syman2000
When you click on Collaborate>Publish settings, check on the missing sheets. Once you reupload the drawing, your missing sheet will showup in Autodesk drive.
anat
Thank you! problem solved.
