Sheets and Printing Extents
gideon.botesB4GMB
gideon.botesB4GMB
Help to solve this issue would be appreciated. Using Revit 2022.
I am trying to print a Sheet in Revit that someone else created.
The print preview won't align with the page, no matter what I do. Also, when I zoom all or zoom extents, the view zooms way beyond the border.
As a control study, when I create a new sheet it prints (and zooms) perfectly.
I think there is something that is invisible, but it won't show up when I select "Reveal Hidden Elements".
I have also gone to every view in the sheet and made sure that Crop View, Crop Region Visible and Annotation Crop is on - but none of those reveal any problems.
Something, where on a sheet or in a view on a sheet, stays outside of the sheet border on the left side. Check and fix it.
gideon.botesB4GMB
Thank you for your response @ToanDN .
I have searched the sheet, every view on the sheet - nothing. I even uncropped every view, and re-hidden invisible objects, then recropped. Nothing gives.
What do you mean on the left side?
Do a cross window selection on the area on the left and area below the border and see if you got anything.
If you print a sheet at 100% and set the print area to not centered on paper then it will print the sheet correctly even if you have elements outside of the border but on the right side and above the bottom of the border.
