Sheet view - view template
sakar_deepak
sakar_deepak
Hi dear friends
When I applied a view template in a sheet view through 'Apply view template to all view', it worked.
But the name of View template does not show up in Project browser.
Now, how does one know which view template is applied in sheet view ?
Regards
Deepak Gupta
Architect
(...... those, who are answering the problems in community forum here, are great people .....)
CoreyDaun
Using this method does not assign that View Template to the selected view; it applies the applicable properties of that template to the selected views. This is equivalent to the option "Apply Template Properties..." in the right-click menu when a single view is selected in the Project Browser. In order to assign a View Template, it must be done individually by view or through a View List (under Schedules).
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
sakar_deepak
Okay,
Now, what is the way to undo the applied properties of that view ?
Regards
Deepak Gupta
Architect
CoreyDaun
The 'Undo' command, if available, would be the only universally certain method. If not, then it depends - when you applied the View Template in this way, it overwrote all applicable view parameters with those of the Template except for those parameters that are controlled by another View Template that is assigned to the View (if there is one). So, unless you have a View Template that reflected the settings of the View prior to the application of the new one, you'll have to manually restore the View's settings.
