Sheet Template
Sheet Template
Sheet Template
Hi
 This is going to sound really stupid, but how do you colour lines?
 Im creating a sheet template and when creating the sheet I change the colour of the lines in object styles. But i understand that when i load the sheet into a project it conforms to those object styles and so the lines turn back to black. Is there a way to keep them orange?
 Could you also help with the parameters. eg making the revision number editable when loaded into a project just like the 'drawn by' parameter where it appears in the properties palette.
Edited by request
Discussion_Admin
Create new Sub-categories with unique names so that they won't conflict when you load Family in projects.
Revision numbers are always editable via View drop down menu \ Revision dialog.  How did you create your revision information and schedule in the first place?
hi thanks for the reply
I did figure it out with this fancy video on youtube
https://www.youtube.com/watch?v=TFRpGWLolAA
