Sheet Collections Filter Bug when "Including elements in links"
I'm encountering what appears to be a significant bug in the new Sheet Collections feature introduced in Revit 2025.
Issue 1: Sheet Collection field not available for filtering
If you try to add the Sheet Collection parameter to an existing Sheet List, you can display the field, but it won't appear as an available filter option unless the Sheet List is created from scratch. This seems like an oversight, especially for firms that rely on standard drawing lists as templates.
Issue 2: "Include elements in links" breaks filtering
Even when you do create the Sheet List from scratch and the Sheet Collection field becomes available for filtering, selecting the "Include elements in links" option causes the Sheet Collection filter to break entirely. The filter stops working, and you're left with a full unfiltered list.
At this point, it seems we’re forced to either choose between:
orFiltering by Sheet Collection
But not both, and this defeats the purpose of the feature.
Has anyone else run into this or found a workaround? Hoping Autodesk can confirm whether this is a known issue or provide some guidance on a fix.
