Shared parameter suppress trailing 0's
Message 1 of 12
Hey,
I have created a new shared parameter of number type, but then enter any numerical data into it, it gives me extra zero's. F.x. I want to insert a data of 1,5 ,but it then re-adjust to 1,500000 , leaving 6 digits after comma. I tried to look into Project Unit settings, but nothing there, no option for suppress trailing when creating the parameter.
I know it doesn't affect anything for calculation or data extraction, but it has to be solved to keep me happy.
Thanks!
Replies (11)
Message 2 of 12
-FDC-
Go to the parameter options (edit label).
Select the hand below the parameter (see picture).
Set decimal places to 5 and uncheck supress trailing.
Message 3 of 12
Hey, thanks for the reply.
However, I find it hard to find Label parameters from the main Revit view...
Message 4 of 12
-FDC-
Try the project units.
You said nothing is there but there is.
Message 5 of 12
This works for the the fixed parameters, but it does not work for the created ones.
Message 6 of 12
-FDC-
I assume it is in a family.
Go to the family (edit family)
Edit the label of the shared parameter over there and reload the family into the project.
Message 7 of 12
Unfortunately, after changing the parameter as you suggested, only the data in the Tag is changed, but not for the setting by itself.
Message 8 of 12
-FDC-
Can you send a screenshot ?
I am afraid I don't fully understand what you mean.
Message 9 of 12
CN3_Duration is my own created shared parameter, with Type of Parameter: Number, this parameter is used for multiple families, walls, doors, columns, etc. In the screenshot it is used for the Structural column and I am looking to find a way to cut down those zeros at the end.
Thanks for your patience!
Message 10 of 12
-FDC-
If you changed the project units and the family units I don't know why it is still not "trailing".
Can you send me that family so I can check it?
Message 11 of 12
BScott
This is for a LENGTH type.  Not a NUMBER type.  How do we suppress zeros for a NUMBER type parameter?
Message 12 of 12
